Hi, I am used to sound designing within a DAW. I’m a bit confused about the limitations of the OP-1 considering the price tag…
- no (workaround: Engine FX + Master FX + sample/resample)
2) no (workaround: two track, one left, one right, route audio to left/right track according to pan)
3) no (workaround (sorta)): resample to drums, slice, re-arrange
4) no (workaround (maybe): clone track, resample using Nitro or punch to filter out/tone down certain stuff
Advice: Don’t treat it like a DAW. Treat it like a 4-track tape recorder with one built in synth engine at a time.
Another piece of advice (not sure it’s needed here, no offense, but just in case): There is no use in asking “why doesn’t it do this” or “why doesn’t it behave like #favouriteotherpieceofgear”. It’s an instrument in its own right. While it might be cumbersome to do the things different than the way you’re used to, it’s just the way it is. There’s not changing that, especially since there will be less and less OS updates (I’ve been told “only compatibility ones” but I’m sure that was not a hard-and-fast statement).
It’s like e.g. comparing a flute to an organ. Yes, they’re both used to play music, yes, they both use air to generate sound, yes, you might be a skilled flute players but if you switch to playing an organ you’re going to have to get used to it. Nobody’s going to fundamentally change the way an organ works just because it’s not a flute. That’s no reason not to learn to play the organ though, if you like the sound of it
Sorry about the rant, this topic has been discussed many times even though you wouldn’t know because you’re new here.
(Edited for splelllingg and, gremmar missteaks)
Another piece of advice (not sure it's needed here, no offense, but just in case): There is no use in asking "why doesn't it do this" or "why doesn't it behave like #favouriteotherpieceofgear". It's an instrument in its own right. While it might be cumbersome to do the things different than the way you're used to, it's just the way it is. There's not changing that, especially since there will be less and less OS updates (I've been told "only compatibility ones" but I'm sure that was not a hard-and-fast statement)...
@destinationsound give it some time. I originally bought mine as a “DAW-in-a-box” and was severely disappointed. Some of the limitations seem extremely weird at first.
@destinationsound If you are already using Ableton, then replacing OP-1 with other synths and pedals is really more a matter of your taste in sound than workflow. I use the OP-1 as a simple “sketch pad” for ideas. Then when I want to flesh out the track, I pull everything into Ableton and add more synths/FX on top of that. So if your goal is to replace Ableton with the OP-1, then you probably won’t be able to do that based on what you are wanting from the OP-1. But if you want to keep using Ableton, then the OP-1 is still a great synth for recording ideas on the go and sequencing, etc. A lot of the sounds you get from the OP-1 you will never be able to get from analog synths (unless you have a lot of space and money).
Thanks Guys
