My latest Pocket Operator Case Design - Beat Box Carbon
I decided to give the successful Beat Box case series a further update by printing the case with GreenTEC Pro Carbon material from extrudr.com
The biodegradable GreenTEC Pro is made from renewable raw materials and has the strength of technical carbon composites, which are used for a wide variety of purposes in motor sports, aerospace and medicine. The material is characterized by its low specific weight, high temperature resistance and high rigidity:
  • High load capacity
  • Suitable for lightweight construction
  • High thermal load capacity 165°C (Vicat VST)
  • Comparable UV stability such as ASA
As with all Beat Box cases, the engraving of the top panel can be customized and different buttons colors are available.
I hope you like the new case.
Cheers,
Torsten
