OP-1 brand new last week. Unit starts charging, then suddenly stops charging (no green lights) It does this several times during a single charge. Switching on the unit to check, the battery shows just 3 green lights.
Seems like the battery meter of your OP-1 needs to be calibrated. The manual says you need to let the OP-1’s battery run empty (until the screen goes dark). Then, keeping it switched ON, charge for about 6 hours. After that, the battery meter will act correctly - at least for some time.
Much obliged, motone. Thanks for your prompt, been digging and see this is an evergreen issue.
No need to force it to drain, just use it the normal way until it goes into battery coma (may be a bit annoying when it happens during an important recording session).
I find DNA or WAVE with the RANDOM LFO, sequenced by ENDLESS is a good screensaver. You can also to add FX and the master section EQ / FX DRIVE to stress the CPU, but I don’t know if it really shortens the battery time.
Thanks again, motone, good stuff.
if you can stand it, I think the battery drains significantly faster when you’ve got the internal speaker turned up…
if you can stand it, I think the battery drains significantly faster when you've got the internal speaker turned up...
thanks beefinator, that’s a neat idea. I’ll opt for the headphones version of that suggestion as I haven’t yet justified this purchase to my kinfolk. Shhhh!
Seems like the battery meter of your OP-1 needs to be calibrated. The manual says you need to let the OP-1's battery run empty (until the screen goes dark). Then, keeping it switched ON, charge for about 6 hours. After that, the battery meter will act correctly - at least for some time. ;)
“Then, keeping it switched ON”
Seems like the battery meter of your OP-1 needs to be calibrated. The manual says you need to let the OP-1's battery run empty (until the screen goes dark). Then, keeping it switched ON, charge for about 6 hours. After that, the battery meter will act correctly - at least for some time. ;)“Then, keeping it switched ON”
@motone, can you cite your source for that guidance please? Thx.CB
@cloudburst
Not OP, but according to TE’s help section:
“to recalibrate the battery meter please do the following:
disconnect USB, turn your unit on and leave it on until it turns off by itself. do not manually turn off the unit. this could take up to 18 hours. the unit is off when the screen has turned black.
after this, charge it fully using a computer or any standard USB charger. this can take about 2.5 - 6 hours depending on your situation. (the battery is 1800mA). this should recalibrate the battery indicator.”
It doesn’t say to turn the power switch to the off position, so doing so would be not accutately following directions that are fairly clear. It states “do not manually turn off the unit.”
I believe the direction not to manually turn off the unit simply refers to the draining process. I believe it’s a mis-interpretation to apply this to the charging process. Buy hey, what do I know? lol
