when inserting notes (per step) from an external keyboard the OP-Z just grabs the last played note and not the whole chord while the sequencer is running.
if it’s stopped there’s no problem to hold down a step and inserting chords with all notes playing on that particular step.
this only happens when an external midi device like OP1/Qunexus is used for inserting notes.
The big advantage with this update is that now when you are playing chords with long long release times, you won’t have notes getting choked out when you hit your next chord. It will make chord progressions a lot smoother.
This was one of the big things I really wanted for the chord track, it made it hard to do ambient pad sounds when each chord would chop off the tail of the previous.
