OP-1 doesn’t like subfolders. Put the files directly into the drum folder, or create a new one in the root folder next to drum/synth/album/…
The OP-1 is smart enough to identify the patches as synth or drum.
Thanks for your reply. I tried putting things directly in the root folder, but that didn’t work. However, I dumped a bunch of files into the /drums folder and that did the trick! I now have a bunch of new drum kits when I go to Drum Mode > shift+1 to select engine > select DRUM with blue encoder > my new kits show up when I scroll with the green encoder. Yay!
I think you may be pressing shift & T1 (of the T1-4 keys) to change engine only. Where you want to press shift & 1-8 keys to load presets and snapshots into 1-8 memory keys.
Hi, Thanks for your reply. I am doing shift+T1 (the 1 key under the display) and selecting the sampler with the blue encoder and then scrolling through factory default patches with the green encoder. My new patches that the OP-1 said were successful loaded are not in the list.
Hey man, I’m pretty sure any synths you load in should appear in the “snapshots” folder, rather than the “sampler” folder. I don’t have my OP1 to check RN but think that’s the way it works.
Hey man, I'm pretty sure any synths you load in should appear in the "snapshots" folder, rather than the "sampler" folder. I don't have my OP1 to check RN but think that's the way it works.
OK, will give that a try tonight! Thanks!
you should be able to put your presets in folders within /drum and /synth
OH docshermsticks, You helped me sooo much! Thanks
always happy to help
thank goodness I came across this
