No audio over usb man. I have a bit of noise when I use my Saffire Pro40 but not on my m-audio transit card. I’m curious whether or not it ‘likes’ sound cards that are getting AC power. Idk dude. I usually save a piece of tape for single tracks to export before I start bouncing. That way I can mix in ableton or protools if I want.
Thanks. Gotcha. Yeah, guess I was just wondering if that was just the way it was or if there’s anything I can do to minimize the noise.
Are you using extreme drive settings or anything else strange in the master fx?
Plugged into my Focusrite Scarlett 18i6 the OP-1 is very quiet, so it is possible with certain audio interfaces.
So I think I figured this out-
basically the op-1 has just a little bit of noise … With anything… But it’s not deal breaking as long as the volume is up all the way. I think I was just plugging in with it wherever I left it with headphones on and added more gain on the interface, which just raised the noise floor. All good now.
thanks for the responses.
This is my experience with noise:
This is my experience with noise:No usb :Almost no audible noiseUSB connected with charging disabled :Some audible noiseUSB connected with charging enabled :ZOMFG duck for the laz0rs!!!If need be, you can always contemplate on just importing tape tracks with 0 noise.
^^^^^ YUP ^^^^^
even if drive is a little bit on you get noise. turn off completely and also turn down the input red knob when in tape mode incase of effects like nitro.
I get the noise when the OP-1 goes directly to the mixer, not to the soundcard
http://hifimediy.com/usb-isolator
One thing is quite strange is that in my unit I am able to turn off the noise almost completely when the OPT mode is enable in mac, but win Windows it works for a few seconds and the noise comes back…
Had a similar experience. tried several cables / adapter / soundcards / etc.
