OB-4 Dead
Hi there,
I have a red OB4. Did not use it quite a while. Decided to switch it on; nothing. Put it on the charger: nothing.
Any advice ?
If you haven’t used it in a while the battery might be in deep discharge mode. You might try to keep charging it for a longer while.
IIRC, there was a similar post in this forum (might have been on Lines as well) with a similar recommendation which helped to revive the device.
As last resort, you might get a new battery and replace the one in your device.
Hi, thank you for your advice.
But should it not work when plugged into the wall outlet?
It should yes
