Hey,
For traveling I would like to buy a harddrive to store my tape/projects. It should have a kind of display to be able to organize your projects and load certain tapes back to OP1. Anyone know some good/compatible ones that worked well for them?
Hey,
If you’re thinking you want to connect the OP-1 directly to a hard drive over USB, you can’t do that, of course.
I have a Samsung 2TB SSD about the size of a matchbox or a little bigger that works really well with my laptop. Might want to consider that.
connect to your phone and store the files there. could probably connect storage at the same time.
If you’re happy to get your hands dirty there are a bunch of projects that might do what you need:
Also keep in mind OP-1 mounts to a computer type device as normal external storage, OP-1 Field appears as an MTP device which is more an Android type thing, so you need something which can read that.
Thank you guys, I think I will use my phone then, though the GitHub stuff seems really exiting, too.
