OG OP-1 MIDI Control
Hey Guys,
I just was wondering what things can be done on the OP-1 in terms of MIDI and external gear.
Sofar, I understand that you can trigger parameters of your patches with the MIDI LFO by midi-sending devicies.
Also you can use MIDI mode in the COM Section to use OP as a Keyboard/Controller or receive ext. midi parameters, that slave OP.
Then also, you can sync OP and ext. Gear to have perfect matching rec/playback/loop.
What else cool things can you do with MIDI?
Can OP1‘s sequencers master external gear over usb, for instance?
I have been using the OP1f with the EP133 through MIDI. It is very easy to setup. Lots of fun!
