Seems like the power switch on my OP-1 is wearing out. Only turns on intermittently. Have to keep flicking it back and forth.
I pulled the I/O board out and took the the plastic cap off the switch. The switch action feels real “mushy”, no real snap to it.
I have a new I/O board from iFixit, which I assume will solve the problem. But, if everything on the old board, except the switch, is still good, I’d like to try and salvage it rather than just trashing the whole thing.
Anyone know specifically what part is used here. Or something compatible with the same footprint?
You mean the switch action feels mushy even without the plastic cap? Just removing the plastic cap did the trick for me, the switch itself works fine, just need a pen or something now to reach it.
also honestly worth a try
sometimes just spraying a lil deoxit inside the switch
and working it back and forth real good
will bring it back to life for a good long while
Put in the new I/O board and that has solved the immediate issue.
And yes, it was the switch itself (without the plastic cap) that was mushy. The one on the new board had noticeably more snap to it.
Thanks for the IDs on additional parts. I should probably stockpile back-ups, for the cheap, readily available stuff at least.
Maybe there should be a Sticky thread (does this forum have those?) of all positively identified replacement parts/components for the OP?
Pretty sure I have some flux, and some Chip-Quik, somewhere. From when I did this thing: monotron-E – Pulp Logic way back when.
