Hi, is there a way to backup and restore the default patches of older OP-1 OS?
Here’s an archive of 14203: https://drive.google.com/drive/folders/0B6r0Q-Lf6Fe5QVoxV3RBYm5DaFU
Thank you but I think there went something wrong. No files in the folders?
Did you click all the way through? I can see files in there.
Yes. But I think I moved the folder accidentally to my drive?
I think I misunderstood. If you copied the patches to your OP-1 you need to put them in a different folder that doesn’t have the same name as the ones the OP-1 uses
Yes I know. Thank you!
Does anyone have the drum patch that has Acetate, Allspice, Awa Beef, Bronze, Cork, etc? My OP-1 doesn’t have those drum kits.
these are, i believe, some of the new factory patches that are included in the newer OS’s.
if u dont ahve these patches u prolly have an older OS loaded
update your firmware to get these patches
