https://soundcloud.com/multivacs/post-eulogy-p1
Pretty good!
Are the strings/synth op-1 synth engine? Or sample? Sound real nice. Mine arrives today, didn’t think it could do synth sounds like this, little beast
Are the strings/synth op-1 synth engine? Or sample? Sound real nice. Mine arrives today, didn't think it could do synth sounds like this, little beast ;)
Good question, it is all OP-1’s synth engine. I used the Cluster synth with a long attack and long decay. Also added Nitro (effect) to remove some of the low end. Then in Tape I added a tiny amount of reverb to everything. Ideally, I would should have moved the field recording from center to left/right, but I couldn’t edit in the OP-1.
Sounds great and thanks for the settings into. Might have to dial it in here Had a couple of hours on OP so far, the synths are actually a lot more variable than I’d imagined from only 4 parameter knobs. What’s going on under the hood has been really well put together by TE.
