try a factory reset/system test(hold com on startup.) or maybe there is some chips under the keybed. I have to do this all the time for my friend who plays keyboard.
thanks for the reply!
yeah I tried all the tests and it works everytime but still I get this intermittent issue - I can’t imagine there being a problem with the key or something being under it - It seems related to processes and load which is why I wondered if anyone may have had the same problem every now and then.
If it was a common issue then I would know not to worry and just hope for an update.
Looks like I might be sending it back - which I really hoped to avoid!
i’ve noticed my op1 slow down on at least one occasion but not enough to be an issue just yet… hope this helps
I get slow down on the graphics but never the audio or a button press.
I’ve noticed a slow down when trying to record to a 3min filled tape, like the tape was literally slowing down just a little. I’ve also had the 4 knobs freeze up once, but just restarted and was good.
Does the OP-1 cache your deleted tape material? I delete a lot since I'm learning, but I factory reset once I pump out three 16-bar beats and start over.
it sometimes falls out of sync with contents of track#.aif files and the database containing information about the “takes”. it’s just buggy.
I have key 8 or sequencer turn itself on from time to time.This is intermittent.Not too much of a problem (alarming if it switches synth voice,as I have a bass preset in unison on 8).I was thinking dust and was hoping it would wear itself out, but it could be the unit.
Thanks to all for responses
@ Spheric_El - I think your issue is probably the same as the one I have… just a different key. Mine has also switched functions/ synths without me pressing anything but note keys while playing. It doesn’t happen often and I can’t seem to force / replicate it - it’s random and just throws me everytime. I can’t imagine it being fixed if I sent it back. Gonna hang on for while to see if the quirks get quirkier! Perhaps my OP-1 is alive … the built in AI chip has finally become self-cognizant and is trying to tell me I am making truly awful music.
Lol
So I finally had enough, bit the bullet and begrudgingly sent my OP-1 back to Baxshop.nl where I bought it.
Yep, same here. Bax send me a temporary replacement because of the long waiting. Love their service!
Hey Marijn - Yeah Bax are great for sure - they normally deal with everything very efficiently but how long have you been waiting now - I presume TE must be overwhelmed with… something? A replacement would be ideal - it’s pretty much a shiny and new unit under warranty anyway -
And out of interest - what was wrong with your OP-1?
I also get the sequencer randomly popping up sometimes… good to know I’m not the only one. Also had the graphics slow down when using Cluster once or twice. Hopefully everything gets sorted for you soon!
