I have just bought the OP-1 and it is a work of beauty. The build quality is excellent and the sounds are unique and interesting. Anyway i am wanting to connect my iPad Air to my OP-1 through the camera connection kit. My question is will I need a powered USB hub to make it work or will it work with just the USB connected from the OP-1 to iPad Air without the “Too Much Power” message appearing?
should work fine - does on mine
Thanks for the reply.
I got the camera connection kit and indeed it works without the “Too Much Power” message appearing on my iPad.
Only one issue is that when my OP-1 is connected to my iPad there seems to be a slight noise coming from the OP-1 speaker. Is this normal?
Try disabling USB charging while it’s connected to the iPad…
Shift + Com --> Opt (T4) --> turn blue encoder
Works fine now. Thanks.
