I am using an OP-1 with Logic on a Mac using High Sierra. I have seen some tutorials on integrating the OP-1 with Logic on Mac but none using High Sierra and the versions of Logic are more current than mine. I am using Logic Pro X.
Problem: I am able to connect the OP-1 and use it as a midi controller, however, I am not able to play from the unit into Logic and record from it as if it were an instrument. I have seen people doing this via usb, but I can’t get that to work. I can hear a faint sound over static occasionally but sometimes nothing. Anyone using OP1 and High Sierra? If so, what is your setup on the Mac and in Logic. Thanks!
