So I was messing around at the very end of my tape and I came across a bug. If you have piece you want to slide [(Shift) + Blue] to the end of the tape, don’t. When you do this, the clip stays in slide mode and can’t be moved or lifted out. Also changing tracks is disabled. You’re stuck recording on whatever track you selected last. The way to get back to normal is to reboot. When you power back on the piece you slid will be missing. Please let me know if you also have this issue.
Yep, just as you said. it just disappears. you can still record on the track but the old slid sections in GONE FOREVER!
