Hi operators
i got my new op-1 today … 30 minutes ago. I unboxed it immediately and turned it on. But nothing happens besides a very short and silent noise from the speaker. No display, no charching LEDs … nothing. I felt the power switch was somewhere between on and off. Maybe the battery is totally empty? What can i do? Really disappointing experience so far.
Don’t worry too much, @waldi.
![:wink: :wink:](https://op-forums.com/images/emoji/twitter/wink.png?v=9)
Ok. I’ll try it. Really hard for me NOT to play with this beauty.
Charging now for some hours, no sign of life. The usb charger i use is not warm as it is when charging other devices. (i tried different cables, ports and chargers from 1 to 2.1 A) Seems like the op-1 refuses to be charged. Could it be that the battery is too old or too drained?
Or shall i still leave it charging over night and wait … and wait … and wait?
Sorry for my impatience.
If it is completely discharged, this might be bad for the battery, but I don’t think it might be killed by doing it:
Only thing I can think of is that maybe you got the on/off switch in the “On” position (down) still which might stop it from charging due to it being deep-discharged.
Sorry to hear about your experience so far. When you charge it, are you seeing the LEDs on the right hand side of the unit? Have you tried charging from a USB port on your computer? Can you enter the COM screen (hold down COM while switching the unit on)? If you can enter the COM screen try reloading the firmware.
Have you tried contacting support yet?
No, i did not talk to the support yet.
The unit does not show any kind of reaction, no LED lights, no display interaction. The power switch is off. I tried switching on while holding COM and i tried the HELP button. The only thing coming from the op is a hardly noticable, very short noise from the speaker when i plug in the usb cable.
Does the OP-1 charge when switched to “On” or only when switched “Off”?
Ok … now i am really confused. I read some other threads here on the forum and one user said "Try unplugging it. Sometimes mine won’t power up when it’s connected to power/USB."
So i unplugged the cable and tried TE BOOT immediately. And it worked. First time some letters on the display. I upgraded the firmware, restarted the unit and now everything workes fine. The battery is fully charged which explaines the cold usb charger.
So now i am happy and ready for digging into the deeps of the op-1. Thank you guys for your help!
Congrats, have fun! I bet you won’t be able to sleep tonight
Great! Glad you got it sorted. Now you can work your way through the tips and tricks thread and enjoy!
The battery is fully charged which explaines the cold usb charger.Might be worth while to keep track of the “uptime” you get out of the battery. If it’s significantly lower than let’s say 8 hours (half the TE claimed 16 hours) you might still want to consider sending it in…
phew. just came in to confirm if everything’s fine. congratz
Good morning
Did you try to update the firmware? Try it even to override the same firmware that your op1 already had. It worked for me few weeks ago.
My OP-1 does not have anything rolling around inside it. At worst it may indicate a damaged component. At best it will be a piece of unnecessary debris which may be noticeable should you use the gyroscopic LFO.
Talked to the reseller today. I will get a new unit in about 1-2 months.
![:slight_smile: :slight_smile:](https://op-forums.com/images/emoji/twitter/slight_smile.png?v=9)
