Does it load the diagnostic menu if you hold Com when you power it on? If so, you can restore the operating system from there. I had success with that when mine wouldn’t turn on.
Does it load the diagnostic menu if you hold Com when you power it on? If so, you can restore the operating system from there. I had success with that when mine wouldn't turn on.
This sounds similar to what happened to me in early January. I rested it on a cold surface, it actually got too cold to turn on. Then I tried wrapping it in blankets and charged it. It was fine the next day.
