I made a tool for Renoise that exports sliced samples in a drumkit format compatible with the OP-1. Slices created in the Renoise Sample Editor are preserved when the sample is exported and loaded into the OP-1. The tool also features a simple ‘auto’ slicer which will slice the selected sample into a specified number of equally spaced slices.
If you don’t know Renoise, it’s a tracker with a fully featured Sample Editor that has a sample slicing feature (similar to Propellerheads Recycle). It also has an API which allows custom tools to built that extend it’s functionality, this is such a tool that exports sliced samples, that can then be loaded into the OP-1 drum kit.
The demo version of Renoise is not time limited so you can just use it as a sample editor and export sounds for the OP-1 with this tool.
I made this for personal use as I have been using Renoise as my main DAW for a few years and wanted to export projects for jamming in the OP-1. Thought it would be nice to share it and I’m happy to consider feature requests for this if there is interest in it…
Cheers! Yeah the demo restrictions are fairly relaxed, I think no ASIO support and rendering… but the rest is fully featured… also very cheap if you do want to buy it.
Yes it prevents you exporting a sample over 12 seconds. Nothing more sophisticated than that at the moment, but have considered adding options for different approaches i.e trim each slice
