OP-1 Field Bag and Strap - how to setup?
OP-1 Field Bag and Strap - how to setup? Unsure how to make them work together to wear it over shoulder. No instructions of course.
I can program up a nice synth patch, but attaching a strap to a bag, well that seems a bit tricky :wink:
There is a section of the strap that you unvelcro and route through the section on the top back of the OP-1F case the has two open ends.
Once you snake it through there (took a little effort) you should be able to re-Velcro and have a little strap bag!
The strap should go over your head, rest on one shoulder, the op-1f should be under your other arm
Thanks!
