OP-1 + iPad Mini (first gen) = Midi behaving weirdly
Hey everyone my first post here, hooray. (actually been stalking since 2014)
So I just got my CCK from apple and urgely tried to connect with my iPad mini (first gen). It didn't work as expected, it keep disconnecting on Animoog and Auxy.
I then downloaded this MIDI Wrench app to evaluate what was happening, and it showed that my OP-1 was blinking between online and offline mode. The thing is, when I tried with my iPhone 6, it worked perfectly (always online). Here is a short video about it: dropbox video
Do you guys have any other suggestion? (apart from buying another iPad, hehe)
Thanks a bunch!
My op1 sometimes doesn’t like chatting to my iPad (Mini 2) directly due to power issues. Stick a powered USB hub between them and they’re best of friends.
I would try disabling charging on the OP-1 (under COM options)
In my experience that makes no difference.
Thanks @ghostly606 and @el_wombato. I will get a powered usb hub and test it out.
Update: disabling charging on the OP-1 solved the issue.
Thanks!
Thanks!
Good to know, I will try that again.
