Has anyone noticed the timeline usually is totally synced 1:1 tic for tic when usb-c connect the op1 and ko2
But lately the op1 midi clock is starting on the half beat when I hit record. So it didn’t start on the 1. Then when I hit play it will start at 1.1.1 as. It should
Anyone else see strange midi clock and timeline behavior ?
Have you reset, cleared loop points/ markers on the op-1 tape?
Thanks for the reply
So far it seems track dependent which confuses me
One track syncs perfectly, other tracks it doesn’t click in on time or it comes in sometimes and not others
Other time the clock will go up to double speed
The fluctuations in consistency are very confusing
Someone suggested cables might be the cause. (My current main cable is 4 yrs old) and switching cables seems to have helped a lot
I’m uncertain whether it’s solved, will update
As per your suggestion : yes markers were clears and loop disabled as well …do you mean reset the op 1 or try a new tape. It does differ tape to tape
