Hello! Im new here. Greetings to all!
Couple of days ago right channel from my op-1 stoped working, im getting audio only from left channel.
If i turn down the level on left level i can hear very quite audio in my right ear and the level adjustment works, so i can change from zero to very low level on right channel.
I tried to resolder jack connector on i/o board - nothing… then i unsolder all 5 legs removed the connector and soldered 3 wires directly to board - still the same, i can hear only left channel.
Could it be i/o board issue and replacing it could solve the problem?
Or it could be some internal issue, something like preamp burned (maybe powering on a RME 400, while OP-1 was connected to mic/line inputs and was turned on was not a good idea…)?
Will appreciate any help! Thank you.
