Hi
Can one do midi-in on the op1 and sequence it from Mac or iPad?
Could you tell me how to set it up for sequencing from the Mac?
I can set it up so the Mac sees it as a keyboard for Garage Band, but the other way …
Edmund
Hi
I’ve sequenced mine from Numerology. You just tell your DAW where to send that track’s MIDI. It’s something like ‘OP-1 MIDI Device In’ iirc
yes, if you wanr hold down shift + com you get into the set-up mode and there you can hold shift again and turn the blue dial to change the MIDI channel.
