Alright alright alright. My brain is fried thinking about this. So let me brain dump here and see where we go with this.
Looking to use all three sweet babies in a little sessshh.
Things Used
- OP-1
- PO-20 (or 128)
- and the K.O II.
Sync Order Idea 1
I want to sync these sweet angels together. With sync in mind it feels like the order should be.
K.O II, PO, OP.
Tempo is easiest set on the KO so KO goes first. then because it’s hard to mix input sound and generated sound on the PO, it goes middle.
BUT. Let’s remember that Tempo and Tape are a thing on the OP-1.
Best Order for Performance
Alternatively from a sound perspective it would go
PO, KO, OP.
This way all previous sounds can be recorded onto tape on the OP-1.
Alright, with all that being said. Here are some goals and rules.
Goals
- Be able to use the KO II effects for all the stuff
- Be able to record into the OP-1 from all the stuff
- Be able to mix the sound of the PO better (if sound comes into the PO, it’s weird. You can’t downmix the PO without also turning down the input)
- Tempo should sync across devices
- Tempo should also sync to tape on OP-1
Alternatives
Syncing these devices in line may be an issue, it make make more sense to purchase something like the TX-6
What is everyone’s thoughts on how you’d make this work?
