Op-1 sometimes wont play a key for a few seconds after leaving idle, updated firmware not sure what the issue is at all but if anyone has any idea i’d be very grateful for any help
Volume level is lower than normal for a few seconds after turning it on… are you sure it is not playing at all?
do you have cow fx on the master effect with the delay all the way up?
Are you sure it’s an op-1 problem?
I had a similar issue until i discover that my speaker (an iloud) goes in standby after leaving idle
my little JBL speaker that I run the OP-1 into sometimes will do that if it remains idle. Does it do the same thing if you are using headphones or the internal speaker? assuming you are plugged into an external speaker…
