OP-1 sound to Moog Mother 32
Hello
Hope everyone’s doing well and is enjoying making some sounds!
I’m trying to connect my OP-1 with a Moog Mother-32. My Goal is to send the sound of the OP-1 to the Moog. After a quick research (I’m relatively new to electronic music and don’t have too much knowledge) I found this to be the setup to make it work (pls see attached images). However I’m not getting any sound.
Any clues what I’m doing wrong here?
Thanks a lot for your help!
  • Y
I dont have a moog but in my neutron i can patch it similar but I need to open the VCA to get any sound. Havent found it out yet.
M32 treats incoming audio like any other sound source (oscillator). You will need to mix it in to the audio path and open the VCA—flick the VCA Mode switch to ON.
If you want to use the M32 envelope generator (EG) on the VCA then you’ll need to trigger the envelope at the same time as the OP-1 note is playing. One way to do that would be to take MIDI from your OP-1 (over USB via DAW) and out to M32. OP-1 would then be both controller and sound source for the M32.
