Hi guys,
I’ve had that happen a few times. I think you can use shift+lift to pick up the 4 track region and it should be there when you paste it back. Maybe paste it to a blank space first to be sure. I think overdub works too.
Happens sometimes. Restart should clear it up.
Restart didnt work and neither did the shift lift…
factory reset. Powerup while holding COM.
Restart didnt work and neither did the shift lift…![]()
Really? Is the sound still there? Try backing up your tape… then overdub it with nothing. Lift that and see if it works.
@masteroaffstuff will the factory reset kill my current project? Probably right?
yup
Just make sure the region is in a loop and lift all tape tracks with shift+lift. Alternatively, you can turn the record gain down on the tape screen (orange) and record silence over the region to restore graphical representation. I find that this happens fairly often, particularly on tape regions neighboring an area where I perform a shift+lift operation to lift all tracks. It is annoying, but easily remedied.
@Lymtronics Thank you dude. Very much appreciated – is this a known bug? It’s super annoying. To make matters worse there is no “Undo” function… yikes.
