OP-1 (v1) & TE ASIO driver
Been a long while since I wanted to hook my OP-1 up as an interface (on Windows) - only just noticed that TE have their own ASIO driver now, most recently updated a couple of days ago too.
I downloaded/installed it, but after selecting the driver (“teenage USB audio device”) the further dropdowns (I/O on Reaper for example) are blank.
Does this driver not work with the original OP-1? I reinstalled TE’s fw 246 (rather than the modified one I had on there) in case that was the issue, but it’s made no difference.
I don’t use Windows for Audio stuff anymore. All usb audio is class compliant low latency on the Apple side of the fence.
But for this I’m assuming if it’s a recent update, it’s Field only. Still pretty cool they did that though.
Try ASIO4ALL?
Yeah, I wonder/assume that too, but on the website it neglects to specify that - says it’s for all TE devices that can act as interfaces.
And ASIO4ALL does work, up to a point, but it’s impossible to avoid a feedback loop with it if you want to use the OP-1 for monitoring as well as input. Ah well!
