Hi everyone,
Now that I think about it, for nearly the same price I might benefit more from an Octatrack. I won’t be able to travel with it but in the studio it will be able to sequence my external gear (which I simply play on the keyboard or sequence in piano roll atm) and then use it for live.
OT is probably the last thing I’d sell if I had to get rid of everything. But I use Op1 more often. Simply down to hectic family life etc. You’ll (probably) be blown away by either of them. They’re both super creative/quick/weird/unique machines. OT is a lot more serious in terms of memory/projects etc and overall features. Op-1 is more instant/streamlined. And obviously fully portable if that’s important to you. Hard to recommend one over the other but probably OT by a whisker unless your daily life situation will make OP-1s portability a deciding factor.
Don’t forget you have to learn for one year to get the Octatrack diploma ; ) With the OP-1 you can start right now!
There is software for iPad/Mac that turns your iPad into an audio interface. Just plug it in with normal lightning cable and it will show up in Logic. True story.
Edit: studiomux/midimux.
The octatrack does not require a year to learn, but it just requires a different mindset when learning it. Dont ask “why doesnt it work like other samplers” or “i could easily do this within my daw” etc and try to wrap your head around one function a day.
It took me two weeks to learn the basics and within a month i am using it as the centrepiece of everything and doing stuff like the transition trick, which i thought i would never use as it looked so complicated before i bought it.
For what its worth, it took me two weeks to learn the basics of ableton when everyone says it would take a day or two, so i aint no tech whiz either.
Would highly recommend one
Thanks for the input guys. I’m finding it really difficult to pick up one so far.
Try some contact cleaner on that Maschine encoder if it’s still giving you problems.
There is software for iPad/Mac that turns your iPad into an audio interface. Just plug it in with normal lightning cable and it will show up in Logic. True story.Edit: studiomux/midimux.
Or you can just go into the macOS Audio MIDI Setup app and enable your iOS device as an interface.
