I have a bunch of bluetooth WIDI jacks and while I can get them to pair and send midi Start/Stop, Clock doesn’t work. In the OP-1F midi config page (Shift Com) The CLOCK just shows OFF and is unable to change by the brown knob.
Anyone else have this issue with bluetooth or is it just me with the WIDI’s.
Unfortunately, I heard that field does not support clock transmission (and reception?) via Bluetooth.
I also use WID, but I can’t use clock synchronization between devices. However, I don’t really care about short loops because they can be used moderately if they match the same tempo.
I think that it is faster to connect a cable when requesting severe timing.
