Just an FYI that they seem to pair pretty well together, and if you keep an eye on eBay you can pick one up for not too much. I managed to get a pair for $45.99 including shipping.
The cord is long enough that you can set it to one side and record room ambience while using the tape or vocoder, or of course pick it up and make other sounds with it.
Yeah, I was surprised by this too. The spec sheet only says “stereo input jack” and “headset support” for each of the ports.
Of course, you can run line in into a mic in; it’s just too hot and you need to tweak gain. The problem’s the other way 'round. Maybe it’s mic input level?
i have this microphone. IIRC it is very noisy. more specifically it’s not very sensitive. should work for mic-ing up close, but you’re better off using virtually any other mic.
I used this mic constantly for field recordings in the very early 00s, attached to a sharp minidisk recorder. It was really low noise with a vivid stereo picture. We couldn’t believe how good it was. Lots of minidisc bootleggers used them at gigs too. I’ve nothing but love for it. Mine must be in a cardboard box containing the tipped out detritus of desk drawers during a move, several moves ago…
I had this microphone paired with a portable MD recorder. Back in early 00’s, I used to make some lovely field recordings in my neighbourhood, in supermarket and while traveling. I recently tried to hook it to my OP-1F and found it to be very low. If my memory serves me well, it used to be way more sensible with my MD recorder. Can’t really explain why…
