Has anyone found a way to export tapes from disk to iOS? It doesn’t work for me, and it’s so frustrating.
No. The OP1F uses the MTP protocol for its file system over USB, which iOS doesn’t support.
Such a bummer. Thanks
Yes, just connect it to IOS as you do to a laptop or desktop. Then switch in the COM menu from MTP to Disk. Now the OP-1F will pop up in the files app as a “disk”.
I use it all the time
The issue with going into Disk mode is that you can only see the drum and synth folder. There is no way to access the tracks/tapes without going into MTP mode.
To access tape? I can access samples fine but not tape
As far as i tested it works. Let me check tomorrow again to be sure!
