OP-1's sounds in ableton
Hi,
I’m trying to record midi from OP1 to Live 9.7 Lite. The midi goes through and records, but the sounds are only kept
while the OP-1 is connected, and if I export the song, no sound is heard. What am I doing wrong?
By the way, my setup is:
OP-1 > Macbook Pro using USB
OP-1 > Focusrite Scarlett 2i2 Using audio out
Focusrite > MBP using USB
Thanks so much!
The setup seems correct to record both MIDI and Audio from the OP-1.
If I understand correctly, you successfully recorded MIDI but didn’t get the audio, right?
How did you set up to record audio in Ableton?
If you’re new to Ableton, perhaps you’ve missed the CMD+click on the REC-arm button for the second track?
Hi Vince and thanks for your reply. There is no OP-1 Audio in, only midi in.
here's how it looks:
Screen Shot 2017-01-28 at 22.24.46
Oh wait, I got it, it works using the Ext in. Thanks so much Vince! :slight_smile:
Cool! the case is solved :slight_smile:
