OP-XY Full MIDI CC List
Does anyone have the full MIDI CC list for OP-XY?
The manual just lists a couple of things and I’m sure everything is assignable. Just as the OP-Z.
Cheers!
i asked this q a lil while back and got this link to a google doc
Something else here:
This is one I made, and I tried to list out everything you can do with CC 106, which is pretty crazy powerfull. You can stitch together any button press combo.
This is wonderful!
Thank you for sharing.
Do you know if there is a similar list of MIDI CC assignments for OP-1 field?
afaik the only CC the op1 responds to is CC1-4 and that is only for the MIDI LFO
The CC 106 commands look promising but I can’t get them to respond (I’m using Touch OSC, and other CCs I’ve tried are working OK)
Awesome work on that CC sheet. Are the CC’s for master EQ documented anywhere?
Master EQ is CC 90 - use channel 1 for bass knob, 2 for mid, 3 for treble. Knob 4 to blend between the EQ and original doesn’t seem to have a CC
Excellent sleuthing!
Hi,
Can you share exactly how the CC 106 needs to be addressed?
Am not able to get this one to work.
Or anyone who actually got this to work.
(I am sending MIDI from Teletype, and everything else works as advertised.).
Thank you!
Hi, can the OP-XY’s eight instrument tracks each respond to note on/offs over independent channels (thus making it ‘multitimbral’ from an external sequencer) or will it only respond to notes on the current active track?
You can send midi note messages to each of the 8 channels independently.
Yes , to all 16 midi channel
Thanks all. That’s super nice! It was the active track midi setting that was throwing me :sweat_smile:
Anyone knows if PATTERNS can be changed with MIDI?
So, there is no way of remotely setting the Record Arm (to use it as a midi loooper)?
TE disabled this after 1.0.21. It was a cool feature but kinda weird since it permanently latches record and shift, and also has no knob automation—making it hard to do a lot of cool things.
I wish so much they’d add changing patterns to the list (not scenes! I know we got scenes already)
100%
I really don’t see why that is not there… I hope it gets implemented eventually.
