If I want to record a snare/clap flam into a single track on the OP-XY such that both hits basically land on the 2nd beat, but the snare is slightly before the clap, is there any way to do this other than (1) just recording it live into a single track or (2) recording them into separate tracks and then nudging the snare step early on its own track?
I haven’t been able to figure out a way to select just the snare note when both are on the same track and then use the minus button to nudge it early without also nudging the clap early.
Maybe a better question is: when you nudge on the OP-XY with the plus/minus buttons, are you nudging the step, or are you nudging notes? If nudging the step, then it makes sense why you can’t create a flam like this.
