OP XY storage and file structure
My understanding is the following.
Samples can be stored on the device organized in sub-folders under the dedicated folder.
The device also supports presets which can use samples (for sampler, drum, multisampler engines currently). These user created presets are compact in regards that the referred samples are stored in the corresponding preset sub-folder (that’s great).
Projects consist of instruments that can be newly created stuffs or based on presets. I suspect the project files don’t directly refer to presets (those are just loaded into the project but from that point the instrument configurations are part of the project). However projects are not self-contained so the samples are just referred and not stored in dedicated project folder.
So samples can be referred from at least 3 places, I think, in a project:
  • sample sub-folders
  • preset folders
  • sample folder (under user?) where the waveforms sampled directly into an instrument are stored
The readme says that if the user wants to move projects from one device to another all the corresponding samples must also be copied. This is the case when a user wants to backup projects or do some housekeeping on the device storage. The OP-XY has 8 GB storage which can be a limitation in long term (based on my calculations it can store ~1511 wav files when all of them are 20s long 44.1kHz/24bit waveforms) and if some sample packs are installed a limited space remains for sampling sounds into the device. However it is not to safe to clean up the storage as deleting samples from the device can break projects and it is unclear how to identify samples used by a given project.
I suspect a kind of collect feature or a tool that can backup a project along with all the referred samples could be very useful.
Hey hey,
Still struggling with the file structure here—really hoping TE puts some effort into improving this in the future.
My Issues:
  • When searching for specific samples in a Drum track, all stored samples are displayed, including those from sample engine presets. This means I have to scroll through the entire list just to find kicks or snares. Plus, the space for file names is too limited, making it hard to recognize them at a glance.
  • Organizing samples by theme is a challenge. For example, when using John Gorton’s fantastic sample packs (shoutout to John!), he organizes his presets into subfolders like Keys1, Keys2, KeysN. However, these subfolders don’t appear as categories (e.g. “pads”) when searching in the Sampler track, which makes navigation annoying.
  • It would be much more convenient if I could work with subfolders properly—allowing me to sort John Gorton’s presets by category, for example.
Really hoping for some improvements here!
It’s in definite need of an archive facility. If the Dirtywave M8 can have such a feature, bearing in mind that Dirtywave is a one-man operation, then I’m sure TE can make such a feature. It could either be on the device itself, or a desktop app. A deep scan to offload any unused samples would be great.
But for all that things that it lacks I am really enjoying it. BTW I also own the M8 Model 2 and it’s a great device as well.
I want to check with active op-xy users. How are things now with organizing samples and multisamples in the preset library? Has anyone had a positive experience in organizing a large number of samples? I also want to know what utilities you use to create multisamples?
Everything is exactly the same in terms of organization, they haven’t changed anything since release sadly.
I don’t use multi-samples very often as I’m happy with the one shot sampler, but on the rare occasion when I want to make a multi-sample patch I use Ableton to have several clips, each clip having one note, and render each clip with the patch name which includes its pitch - eg CZ bass C2. I prefer Ableton over Reason for doing this as Ableton allows the option to render in mono, something Reason doesn’t.
I wish you could import one WAV made of multiple notes and slice them in multi-sampler.
Still happy with the OP-XY but I do wish the sample management was better.
8gb is not enough. Mine is full. We need to be able to add an SSD or sth:(
Yeah, at this price point there should be something like 64gb
i made a tool that lets you free up space on your OPXY. its not seamless since we still have to rely on the fieldkit app to do the file management so the process is:
  1. backup the 3 library folders (samples, presets, projects) to a folder on your computer
  2. back up the backup just in case
  3. drag the first backup into https://opxy.app
  4. convert the samples in one batch process to reduce bitrate/samplerate
  5. reupload the folders to the opxy (i have just been deleting everything off the opxy and re-uploading the modified folders).
the tool does a lot more than that too. https://youtu.be/wotD-rCXreM
