OP-XY update 1.1.15
Lots of changes, release notes are here: downloads OP–XY - teenage engineering
Cut and paste of changes:
  • user content: support for deeper folder structures
  • user content: optimized handling of large data
  • preset browser: allow adding preset folder
  • preset browser: allow moving presets between folders
  • sample browser: group all samples used by user presets
  • sample browser: preview sounds automatically
  • system usage indicators to show voice count, cpu and sample memory
  • improved cpu voice limiting to reduce pops and crackles
  • increased number of patterns per track from 9 to 16
  • project templates support
  • rotate trigs functionality
  • added midi monitor to system menu
  • new sustain pedal functionality (holds notes until pedal up)
  • more intuitive logic for linked track octave offset
  • com: improved device list and device popup
  • mtp: improved robustness & optimizations
  • mtp: utf8 support
  • fix: midi engine bugs
  • fix: slowest manual speed in ‘value’ lfo resulted in 0 speed
  • fix: linked arpeggio not triggering the first time
  • fix: broken combination of hold and random spark components
  • fix: param lock not shown on tape screen
  • fix: midi program change param locks not working
  • fix: BLE advertise sometimes not working
  • fix: stuck maestro notes when switching to scenes/patterns
  • fix: param lock preview with nudged step not working
  • fix: page duplicate missing first note
  • fix: scrambling a MIDI track only produces low values for first CC
  • fix: highlighting current project in project browser didn’t work after reboot
  • fix: arpeggios would always reset at the end of a pattern
  • fix: mute popup shown for midi tracks that aren’t active
  • fix: hanging notes when enabling arpeggio/hold
  • fix: hanging notes when MasterEcho and Maestro is combined
  • fix: hanging notes with linked tracks
  • ui: reset eq with encoder click
  • ui: draw drum sampler fade over waveform
  • ui: draw pattern stacks differently depending on how many patterns there are
  • ui: encoder click to toggle browser sorting mode
  • ui: toggle track quantize with encoder click
  • ui: minor tweaks & touch ups
Good stuff.
The quality of life stuff is REALLY welcome and very much needed. Next update should really include something new. A versatile drum synth would be so good.
Individual note editing on step. Did they just sneak this in the manual and not anounce it or did I just miss it in the previous update?!
You missed it, available pre-1.1.15
Thanks for the update :slight_smile:
UTF8 and folder support, it helps a lot :slight_smile: :slight_smile:
Wish: set default loaded project template when pressing “New”
new sustain pedal functionality (holds notes until pedal up) ? what is that ?
Still no individual note editing. Even focusing on a note you still edit the step affecting all notes assigned to it unfortunately.
This really helps me!
Rick
A such frustrating update :frowning:. Fix of so many bugs I even not noticed lol. Nothing really new, improves of things that could be done in minors updates a while ago. Waiting 6months for this is disappointing. TE please make a major update on: usb multitrack outputs and individual sample editing insert fx in the drum engine at least! I dont understand people who are satisfied with this update
I could experience some bugs and instability, I have low confidence in this update, and rolled back to previous version 1.1.4.
  • Arp mode no more working with brain (the main reason of my rollback)
  • Weird infinite sustain on instruments after manipulating the hold mode (fixed after a reboot)
  • A crash while browsing through the sample folders
  • Renaming a file caused some instability in the browser (looked like in edition everywhere else)
  • Some pops I never experienced before while shortening drum sample length (not 100% sure about this one)
Sound engines, philosophy of the machine and build quality are amazing, the OS part is the weak part…
Darn. To bad that it isn’t actual per step note manipulation.. 16 patterns per track is kinda nice though. Opens up possibilities for some of my old tracks.
The sequence shift is really helpful. Fun to use as a new performance tool as well, e.g. shift a hi-hat part back and forth relative to the beat
Have in mind, this update was from 1.1.14 → 1.1.15. So I still hope for big update 1.2 or 2 :slight_smile:
1.1.4 → 1.1.15 to be correct :slight_smile:
Unusable for me after update - trying to edit the name of a sample is totally broken, eg - trying to delete a character name results in deleting other samples. Hoping for a quick fix.
I’ve been waiting for this update!!! Going from 9 to 16 tracks is a game changer for me! Thank you, TE!
This really really needs to happen. Being able to set conditional stuff for individual sounds on the same step would be so good.
Very nice update, but the brain no longer affecting tracks with Arp on is quite a big problem for me! Hope they fix it soon.
Can this be automated in any way?
@ciaraneditor I didn’t see sequence shift in the list.
Is it part of this update?
How does it work ?
Rick
