add option to save to same snapshot instead of new (hold shift)
add “make default” option to templates
add system setting for sample preview
don’t apply sustain pedal to arpeggio notes
fix: arpeggio not affected by brain
fix: arpeggio not active until playback start or entered arpeggio screen
fix: linked tracks parameters lags behind on pattern change
fix: brain send settings do not honor sound link
fix: pasting a step to first start would not work with negative micro timing
fix: wrong buttons could show up in sample browser
fix: sample doesn’t show up in sample browser after recording
fix: when renaming in sample browser, delete key deletes sample instead of letter
fix: subfolder indicator “/” disappearing when scrolling
Thanks for very quick fixes.
I really love you added “make template to default” and “overwrite shapshot” ![]()
Careful with the snapshot
It will over write blank ( they have already fixed it )
Haha, too late
. I lost two multisample presets. Overwriting multisample snapshots will kill not only the sample mapping but also the samples assigned to the snapshot.
Fixed in 1.1.18. That was quick.
A number of us are having an issue where the device takes up to 30 seconds to load no matter which project or samples are a part of that project. Anyone in here experienced it and has anyone tried a full restore of the device and had any success as some people are suggesting doing that without any evidence that it does anything?
wohooo … save to the same snapshot. Finally. That was the thing I wanted to see most. Thank you for this ![]()
I have factory reset my device, on 1.1.18 fw, and it did NOT fix the slow loading issue on boot. Still locks up for between 15-25 seconds on boot. Not impressed. I think I’m going to revert back to an older firmware if I can.
Mine takes over a minute to boot. Only the transport works. Every other button is unreponsive.
Serious bug and many have it. Some hypothesize that it’s related to certain samples and/folders but nobody has proven this conclusively.
15 seconds here. Although, it has to be said that the Analog Rytm takes a good 30 seconds to load the samples on boot up, so I’m not certain 15-20 seconds is unreasonable.
However, the OP1F boots in about 5 seconds!
Latest 1.1.21 update fixes all my freezing and lag issues reported earlier. Nice to have this fixed!
Mine always start as usual, fast, like 5 seconds or less! no matter the updates. Wondering if it’s because I didn’t put subfolders, I didn’t want to change anything in my library…
New update
OS 1.1.25
new quantization grid for odd track scales (x3, x5, x6, x7)
improve how multisamples work together with global transpose
use normal note off with release when stopping hold player
avoid delay effect reacting to jittery external tempo
inherit current player type when adding a new pattern
improve user experience when preset folders use same name as factory presets
rework the voice stealing indicator, now shows all audible voice-stealing events
fix: incorrect quantizing of notes close to the end of the pattern
fix: overlapping notes causing unexpected arpeggio behaviour
fix: user tunings were inconsistently loaded to the user slots
fix: couldn’t add same note with two octaves apart to step when holding note and pressing step
fix: audio-only USB interface would show as disconnected
fix: incorrect parameter names on epiano screen
fix: muted arpeggio tracks played old notes when hold was turned off
fix: could still input maestro notes when bar screen was shown on top
fix: duplicating a project did not include unsaved changes
fix: sometimes no notes sent on TRS MIDI when clocked via incoming TRS MIDI
so how does this work?
- new quantization grid for odd track scales (x3, x5, x6, x7)
best way to describe it (succinctly) is it probably now works the way you might intuitively think it ought to.
seriously: I can’t remember how to do this…
quantization grid? Where? How?
os 1.1.33 out
- fix: unable to add parameter locks to empty steps
https://teenage.engineering/_software/op-xy/opxy_firmware_1_1_33.tfw
