This is turning out to be a perfect union of mobile playability.
I have this older Vaio Canvas Z tablet that is stable and great at running Ableton Live. Now that I’ve connected the OP-Z to it I’m just over the moon on the setup.
Do you mind explaining a little bit what’s your setup like? Are you using OP-Z to send MIDI signals to the different tracks on Ableton Live or the other way around? I’m curious since I also use Ableton Live and would like to try using it together with the OP-Z
Thanks for the interest. If you zoom in to the photo you can see that i have each instrument in Ableton receiving Midi per channel from the OP-Z.
In Ableton you need to select the OP-Z as an Input Source for the midi routing to work. I’ll take a screen shot later today and post it here so you can see what is ticked on in the Midi Settings.
Hey im aware of the differetn instruments, but is it enough to assign a single channel for every OP-Z channel to get this going? Not working for me in ableton sadly …
Here’s another track from the same setup. It helps to save out a template of the setup, so the next time you open Ableton with the OP-Z connected you can just start jamming.
thats awesome thanks for the share. I’ve only had my opz for a few months but i keep finding out additional things it is capable of and its value only keeps growing!!!
I friggin love this little thing
Here’s the Live Setup Sample file. You’ll need to add your own instruments and what not. Also make sure to activate the OP-Z in the Midi Input in Live’s settings view as posted in the thread.
A few people have requested that i record how to get the OP-Z set up in Ableton in order to sequence your VST instruments. Well…here is that video. Hope this helps and please let me know if you have any questions.
