Hey, bit the bullet again and bought another Op-Z (this time with a warranty, previous one had a bad curve to to it).
Got some modular Moog setups such as the DFAM, and Mother-32. Ended up buying the OP Lab module, I should be able to patch into these correct?
Correct, oplab module has pitch and gate CV output that you can then patch into any modular type system. Also, it has full midi input and output, so you can connect a midi pin cable from the mother-32 or dfam into the OP-Z and then control them using the OP-Z.
It’ll work just fine! If you have 1/8”TRS to 2x 1/8”TS splitter cables you can even use the dials to control two parameters on the Moogs.
IIRC the OP-Lab Module outputs 0v to 5v on the pitch output but the Mother-32 accepts -5v to 5v. This won’t hurt anything, it just means the OP-Z can only sequence across up to five octaves. Use the Mother-32’s built-in keyboard to set the base pitch.
