I am so happy to see this. I have been using some old hand-me-down ios devices when I wanted to use the app. It looks and runs so much better on my newer android. Especially the videopacks and photomatic. Good work TE.
I hope both apps share the same code base so if/when they start adding features to the app they will show up on both versions at the same tie. I really want to be able to pin the mixer page, or select a mixer like I an select videopacks, midi config, configurator, photomatic, or the op-z.
There was an update of the app yesterday- it just says âbug fixes and stability improvementsâ - couldnât test it so far, but letâs hope that some of the connection problems are solved with itâŚ
It happened two times now - it just lost the bt-connection in the middle of something - and had troubles to get it re-connected - op-z off/on, android app kill/start, bluetooth off/on etc⌠no freeze here so farâŚ
After some issues with the app (I could not connect my op-z via bluetooth) it works great! For everyone, having problems, to connect the op-z to your android device, try to reset/delete the bluetooth settings (and cache) and restart.
Do you mean unpair the device? OP-Z doesnât show up in my paired devices, even though bluetooth connection works with the app, but it drops out after a couple of minutes. Then I have to close and open the app again, then connect again via button on the OP-Z. Very annoying, does anybody have any suggestions? I have a Samsung Galaxy A5.
Mine doesnât work at all⌠Annoying, it used to work perfect now it canât connect⌠It seek works with my ipad pro though⌠I tried deleting history and reinstalled the app⌠Still nothing.
