Hi! I updated my Mac OS to version 26 and tried connecting the OP-Z via Bluetooth. For some reason, it didn’t work. The Mac Mini only sees the OP-Z via USB. Is there a solution for this? The Mac app was last updated two years ago. Maybe Teenage Engineering no longer supports the OP-Z?
Oh, did ever Mac (computers vs Ipads/Iphones) see the OP-Z?
Using 2013 MacBook Air with Big Sur here.
I installed the app, but no way to see the OP-Z either.
In contrary to your case, mine is perhaps too old ![]()
Indeed, it would be nice to see the OP-Z app on a so big screen.
Hi, you need to open the “Audio midi setup” app om Mac , then go to the ”MIDI Studio” window. if you don’t see it go to /Window/Show midi studio. then go to “MIDI Studio” in the upper meny and click “Open Bluetooth Configuration..” now press the little button on the OP-Z and it will pop up
Many thanks for having taken time to explain this.
I’ll try that asap!
Happy to help, I have been there and was almost going crazy when I didn’t get it to work
Hi @Victory, it works like a charm!
Again many thanks, I’d never have found that.
@Kosta , is it working for you too?
Thank you so much! The Bluetooth settings are hidden behind the arrow in the upper right corner of the MIDI Studio window. Everything works as expected. Hooray!
Thanks for sharing!
