Hello,
I have been having issues with my OP-Z and recording through the USB. I have my OP-Z connected from usb c to usb c into my iPad Pro. I am using an official iPhone usb c cable that came with my iPad.
When I am recording into GarageBand I can set up monitoring on the iPad and when I press play everything is picked up and and heard through the OP-Z but, when recording, after the first measure the monitoring on the OP-Z will cut out but GarageBand continues to pick up the OP-Z output and record it. The OP-Z will then refuse to monitor the usb input afterwards. It takes a full restart of the OP-Z to be able to set up the usb monitoring again.
When listening back to what has been recorded the recording is filled with moments of scratchy static. And right after the first measure, what would normally be the second pattern playing on my OP-Z, the song starts over again from the beginning.
Has anyone else had any problems with usb recording from the OP-Z?
I have made sure that the OP-Z is not receiving a charge to make sure there would be no static when recording. I’ve tried a factory reset. I don’t know what to do at this point. Any tips or advice would be greatly appreciated. Thank you in advance for your help.
