Hey everyone I currently am using the OP-Z as the center piece in my rig for preforming live and I also play guitar along with it. The idea I have is to send midi from the OP-Z to the ditto X4 to control the loop length so my guitar loop will be in time with the OP-Z.
I’ve never tried anything like this before and I was wondering if any of you have tried this combo before? If so what would I need gear wise besides the OP-Z and Ditto x4 to pull this off?
Also I don’t exactly need to use a ditto X4 and would like any suggestions or recommendations for loop pedals that take midi information and could help me achieve this goal.
I synced a strymon timeline to a edp pro via midi. Timeline was midi Slave. I had two loops playing in sync that way. It should also work with the OP-Z if you have the appropriate midi connection.
Thank you for the tips! Practicing without midi and just building up my chops looping is probably the best, its reassuring to hear advice I should just go for it midi or not!
Did you ever try the original idea? I want to do the same (about to get the op z), I also have a kenton usb host… my concern is that I would also need midi from op z to sync my op 1, hence somehow need to split that midi usb signal I guess…
