Here’s how to use your OP-Z to create your own accompanying light show
How to control DMX lights with your OP-Z multimedia synth/sequencer
Thanks, are there cheaper alternatives?
Well, you will be just fine with the Pro MK I, which isn’t too expensive (and you wouldn’t always NEED the usb hub), it’s the lights that are expensive… like a lot lol.
Good point: Actual DMX lighting is costly… I want a basic DMX setup downstream of the Enttec/Nucleum, of a chain of 16 RGB lights that follows the OP-Z lightshow track.
Can anyone recommend a reasonable cost of some suitable lights?
Not really got the skills or time to go the Arduino route.
