https://teenage.engineering/guides/op-z
the complete op-z guide is online!
cheers…good way to spend my evening
Waiting for someone to put this into an PDF… This is terrible to use…
Huh. After watching Cuckoo’s vid I thought there was only one synth engine per synth track. Pleasantly surprised to see there’s nearly 10!
Thanks @flom
Synths:
bow: string synthesis
cluster: clustered oscillators
digital :digital raw engine
electric :complex and transforming
saw: filtered waves
shade: smooth piano
sample: PCM sample player
uranus: clean bass
volt: multi oscillator electric synthesis
Effects:
type: vector semilinear crusher
type: basic digital delay
type: overdrive distortion
type: digital reverb
slick everything is coming together finally!
I just noticed we have a whopping 25MB available for our own samples! Amazing!
woohoo
___subtractive recording
press – while holding rec for subtractive recording mode. held notes will now be removed from active steps.___
does it mean it will expand on length on its own? omfl
_lead
lead is a track dedicated to synth leads. any note style can be used. the polyphony for this track is three, meaning maximum tree notes per step.
_
originally copied from the manual…is this a hint to bash a lot of 3 note polyphony chords on one step? like layering with step components? I def. like the 2 note polyphony on drum tracks.
…and 4 note poly on chord track for extended chords
So in the manual intro it says “for a deeper Understanding visit the email website and take a lesson”
Anybody know what that is?
meaning maximum TREE ? like a step component tree. that’s the hint
Damn the OP-Z is like an abyss! ??
