so the midi settings are now where FX toggle for microphone used to be and where midi settings used to be are now toggles for different inputs.
but now i don’t understand how to toggle fx on and off
“use shift to access different parameters”
im confused
…(screen-tempo-shift-first’knob)= does something new
… alternative to that combo itso also possible to:
hold (screen), while holding (screen), press (tempo) 3times. than you can release (screen) and press shift and (first’knob).
(oh i got it now. if you want to toggle fx for the microphone its the same shortcut (screen-tempo) but your op-z had to be in vertical position. if op-z is not in vertical position (screen-tempo)will do MiDi settings)
“allow send lvl editing from fx track read more here”
where is “here” , no link
this is a nice touch though:
there are white dots at the bar. easy to see where you place your notes.
built-in microphone, when enabled, doesn’t give a feedback loop noise anymore ! but now it doesn’t show volume lvl when you speak into op-z.
i think this is too early and they are stull updating the manual
app interface shows now what module you have
thats nice👍 it also shows in what configuration switches are on the module. very good attention to detail
extra raw of controls added to track 14
mixer interface has now extra track to mix !
when connected via bluetooth and and using op-z app. when app crushes (or closes) on the background., op-z disconnects bluetooth as well
