I have big problems when using my Opz as a sequencer with Ableton with midi hang and also it not recognizing half of my inputs.
The weird thing is that two days ago I used the exact same setup and it worked perfectly fine (besides the clock sync that also never works for me) and I did not change any settings since then.
Did anyone ever experience similar problems?
Edit: While doing some testing with a midi monitor I found out the the opz often doesn’t recognize the input signal thats why it often doesn’t stop playing or often won’t play. But I still found no solution.
