Hi. Any Op-z, Cubase 12 users out there?
I can’t get my op-z to appear in the audio system drop down in Studio Setup in Cubase 12. Any suggestions?
OS is windows 10, which recognises the op-z as a sound input and output.
Cubase is receiving midi from the op-z fine too, just not audio.
Thanks
Cubase only support ASIO drivers in Windows, and the OP-Z does not have one. You should be able to setup the OP-Z through the Generic Low Latency ASIO Driver option in Cubase.
I’ll give that a go. Thanks
Managed to get my op-z up and running in Cubase using ASIO4ALL
